Salta al contenuto principale
HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement
Cosa ti serve
  1. HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement, Back Panel: passo 1, immagine 1 di 2 HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement, Back Panel: passo 1, immagine 2 di 2
    • Turn the laptop over so that the bottom is facing up
    • Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
  2. HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back panel to reveal the inner components.
  3. HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement, Mouse Touch Pad: passo 3, immagine 1 di 2 HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement, Mouse Touch Pad: passo 3, immagine 2 di 2
    • The mouse touch pad is located in the bottom middle section of the back of the laptop.
    • Lift the black ZIF tab and gently pull the ribbon cable free.
  4. HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement: passo 4, immagine 1 di 1
    • There are four M2.5X2.5 screws that need to be removed in order to take the mouse touch pad out.
    • Unscrew all four M2.5X2.5 screws with a JIS #0 screwdriver.
  5. HP Envy Touchsmart m6-k125dx Mouse Touch Pad Replacement: passo 5, immagine 1 di 1
    • Flip the laptop over and open it.
    • Gently press on the two top corners of the mouse touch pad, snapping it down and out.
    • Remove through the bottom of the laptop and replace.
Conclusione
Aaron Burns
Membro da: 04/06/19
97 Reputazione
1 Guida realizzata
IUPUI, Team S14-G14, Wilson Spring 2019 Membro di IUPUI, Team S14-G14, Wilson Spring 2019
IUPUI-WILSON-S19S14G14
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 207
