Salta al contenuto principale
HP Envy Touchsmart m6-k125dx Hard Drive Replacement
Cosa ti serve
  1. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 2 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: passo 1, immagine 2 di 2
    • Turn the laptop over so that the bottom is facing up
    • Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
  2. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back panel to reveal the inner components.
  3. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Using the JIS screwdriver along with the J000 head, unscrew the four Phillips PM2.5x5.5 screws, and place them aside.
  4. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: passo 4, immagine 1 di 1
    • Carefully detach the Hard Drive Adapter, and remove the Hard Drive from the laptop.
    • Make sure not to pull from the cord; pull from the head of the adapter.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,151
