Salta al contenuto principale
HP Envy TouchSmart m7 k010dx Screen Replacement
Cosa ti serve
  1. HP Envy TouchSmart m7 k010dx Screen Replacement, Battery: passo 1, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement, Battery: passo 1, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Turn your computer over so that the bottom is facing up.
    • Slide the left black switch towards center.
    • You should see an unlock image exposed to the left of switch if done correctly.
  2. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 2, immagine 1 di 2 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 2, immagine 2 di 2
    • Slide the right black switch towards center to release the battery.
  3. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 3, immagine 1 di 2 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 3, immagine 2 di 2
    • Pivot the loose edge of the battery closes to you by pushing it toward the back of the computer.
    • The battery should slide out freely.
    • If battery is not pivoted before sliding out, you risk breaking interlocking tabs on the battery or computer.
  4. HP Envy TouchSmart m7 k010dx Screen Replacement, Keyboard: passo 4, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement, Keyboard: passo 4, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement, Keyboard: passo 4, immagine 3 di 3
    • With the computer turned over use a nylon spudger to pry the rectangular pads off to reveal two hidden screws.
    • Using a Phillips #0 screwdriver, remove the screw that is beneath the black rubber pad, as well as the other holding down the black corner plastic pieces on both the left and right sides.
  5. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 5, immagine 1 di 1
    • Use a plastic opening tool to pop the corners off by wedging between casing. Do this for both legs as depicted in the picture.
  6. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 6, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 6, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 6, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the screw in the center of the computer, and to the right of the Beats logo.
    • Use your fingernails to pull out the optical drive. It will have some resistance to start, but will come out easily afterwards.
  7. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 7, immagine 1 di 2 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 7, immagine 2 di 2
    • Using a JIS #00 screwdriver, remove the two screws that were revealed when the optical drive was removed.
    • Use a Phillips #0 screwdriver to remove all screws that are visible on the bottom.
    • There is an oval tab near the center of the laptop, use the flat end of a nylon spudger to wedge it free to reveal another Phillips #0 screw.
  8. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 8, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 8, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 8, immagine 3 di 3
    • Open up the laptop and set it down normally.
    • Use a credit card or spudger to wedge between the top and bottom keyboard casing.
    • Slide the card all the way around the laptop, making sure to pop free all tabs.
  9. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 9, immagine 1 di 2 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 9, immagine 2 di 2
    • Place the computer on the backside of the screen, so that the bottom of it is pointing up into the air.
    • You may want to place a rag over the screen so that if the front panel touches it while being removed, no damage is caused.
    • Carefully begin to separate the top case from the bottom case, as if you are opening it like a book from the edge nearest the touch pad.
  10. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 10, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 10, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 10, immagine 3 di 3
    • The two panels are connected with 4 flexible electrical ribbon strips. The ribbon strips have a locking tab that will need to be disengaged prior to removal. Using fingers, begin by removing the two strips nearest to the opening.
    • Picture 3 shows the tab unlocked
  11. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 11, immagine 1 di 2 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 11, immagine 2 di 2
    • With the two panels now separated, you can see the other two strips towards the back of the computer. With finger, carefully release each strip from the locking tab.
    • Once all are unplugged, carefully remove the top case.
  12. HP Envy TouchSmart m7 k010dx Screen Replacement, Screen: passo 12, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement, Screen: passo 12, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement, Screen: passo 12, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With tweezers in hand, begin by disengaging the tab on the upper left corner of the motherboard. Using your fingers, disconnect the plug that is to the left of the tab.
  13. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 13, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 13, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 13, immagine 3 di 3
    • Using tweezers, gently remove the two cables connected to the WLAN module.
  14. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 14, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 14, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 14, immagine 3 di 3
    • Using a JIS #00 screwdriver, remove the screws holding the hinges in place.
    • On the left hinge, there is a screw that does not appear to belong to hinge but is (circled in picture).
  15. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 15, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 15, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 15, immagine 3 di 3
    • Remove the screen by pulling it forward from the casing. This allows the hinges to clear the casing.
  16. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 16, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 16, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 16, immagine 3 di 3
    • Use a plastic opening tool along the gap between the screen and the back panel to separate the two pieces.
    • When sliding with plastic opening tool, be careful around the webcam location to prevent damage.
  17. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 17, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 17, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 17, immagine 3 di 3
    • Carefully separate the display unit from its back panel.
    • There is glue between the two pieces, make sure you move slowly.
    • Flip the display unit over. Slowly remove the output cable from clips holding it in place.
    • To remove the two strip running to top of display simply lift to loosen the tack glue holding them in place.
  18. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 18, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 18, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 18, immagine 3 di 3
    • Use the spudger or your finger to remove the tape on the output connection.
    • Slowly and carefully pull the cable out from the connection.
    • Permanent damage can be caused on your computer if you pull the cable too hard.
  19. HP Envy TouchSmart m7 k010dx Screen Replacement: passo 19, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 19, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Screen Replacement: passo 19, immagine 3 di 3
    • To remove the screen from its bezel there are a total of 4 Phillips head screws. 2 on left and 2 on right of the display unit.
    • Use a Phillips #0 screwdriver to remove the screws.
    • The display unit can now be taken out freely.
Conclusione
Owen Ou
Membro da: 10/17/17
443 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,825
