Introduzione
This guide will walk you through the process of replacing a screen in the HP Envy TouchSmart m7 k010dx.
- A screen would need to be replaced if it is cracked, dead, or displays horizontal lines from end to end.
- A screen that is functioning properly will have a clear, crisp display.
- Before you begin, unplug the device and completely power it down.
Cosa ti serve
Turn your computer over so that the bottom is facing up.
Slide the left black switch towards center.
You should see an unlock image exposed to the left of switch if done correctly.
With the computer turned over use a nylon spudger to pry the rectangular pads off to reveal two hidden screws.
Using a Phillips #0 screwdriver, remove the screw that is beneath the black rubber pad, as well as the other holding down the black corner plastic pieces on both the left and right sides.
Using a JIS #00 screwdriver, remove the two screws that were revealed when the optical drive was removed.
Use a Phillips #0 screwdriver to remove all screws that are visible on the bottom.
There is an oval tab near the center of the laptop, use the flat end of a nylon spudger to wedge it free to reveal another Phillips #0 screw.
With tweezers in hand, begin by disengaging the tab on the upper left corner of the motherboard. Using your fingers, disconnect the plug that is to the left of the tab.
