Salta al contenuto principale
HP Envy TouchSmart m7 k010dx Battery Replacement
  1. HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: passo 1, immagine 1 di 3 HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: passo 1, immagine 2 di 3 HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Turn your computer over so that the bottom is facing up.
    • Slide the left black switch towards center.
    • You should see an unlock image exposed to the left of switch if done correctly.
  2. HP Envy TouchSmart m7 k010dx Battery Replacement: passo 2, immagine 1 di 2 HP Envy TouchSmart m7 k010dx Battery Replacement: passo 2, immagine 2 di 2
    • Slide the right black switch towards center to release the battery.
  3. HP Envy TouchSmart m7 k010dx Battery Replacement: passo 3, immagine 1 di 2 HP Envy TouchSmart m7 k010dx Battery Replacement: passo 3, immagine 2 di 2
    • Pivot the loose edge of the battery closes to you by pushing it toward the back of the computer.
    • The battery should slide out freely.
    • If battery is not pivoted before sliding out, you risk breaking interlocking tabs on the battery or computer.
Conclusione
Owen Ou
Membro da: 10/17/17
443 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 741
