Salta al contenuto principale
HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement
Cosa ti serve
  1. HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement, Battery: passo 1, immagine 1 di 3 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement, Battery: passo 1, immagine 2 di 3 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the laptop over so that the backside of the laptop is facing upwards.
    • Use the Phillips #0 screwdriver to remove the twelve 5 mm screws that secure the bottom cover.
    • Insert a plastic opening tool into the opening between the bottom and top cover. Gently work your way around the perimeter of the case, and pry the two halves apart until the back cover is free from the laptop.
  2. HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 2, immagine 1 di 3 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 2, immagine 2 di 3 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the five 5 mm screws that secure the battery.
  3. HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 3, immagine 1 di 3 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 3, immagine 2 di 3 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 3, immagine 3 di 3
    • Peel back the black layer of tape, ensuring that you do not peel it off all the way.
    • The battery connects to the laptop port. This is where you will connect/disconnect the battery from the laptop.
    • Use a plastic opening tool to gently remove the connector from the port.
  4. HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 4, immagine 1 di 2 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 4, immagine 2 di 2
    • Remove the battery by carefully pulling it away from the laptop.
  5. HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement, Touchpad: passo 5, immagine 1 di 2 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement, Touchpad: passo 5, immagine 2 di 2
    • Use the screwdriver to remove the four 2 mm screws that secure the touchpad.
  6. HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 6, immagine 1 di 2 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 6, immagine 2 di 2
    • Once the screws have been removed, carefully pull the piece of blue tape away from the touchpad.
  7. HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 7, immagine 1 di 2 HP Envy TouchSmart m6-k025dx Sleekbook Touchpad Replacement: passo 7, immagine 2 di 2
    • Grab the touchpad piece from the top corner, and begin to pull it up and out to remove it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 89
