Salta al contenuto principale
HP Envy Sleekbook m6-k010dx TouchPad Replacement
Cosa ti serve
  1. HP Envy Sleekbook m6-k010dx TouchPad Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 2, immagine 1 di 2 HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 4, immagine 1 di 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 5, immagine 1 di 2 HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 5, immagine 2 di 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx TouchPad Replacement, TouchPad: passo 6, immagine 1 di 1
    • Lift the white tab on the ZIF connector to unlock the ribbon cable.
    • Pull the ribbon cable out of the ZIF connector.
  7. HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 7, immagine 1 di 1
    • Remove the seven 3mm Phillips #00 screws from the trackpad.
  8. HP Envy Sleekbook m6-k010dx TouchPad Replacement: passo 8, immagine 1 di 1
    • Use the plastic opening tool to lift the touchpad up and pull out to remove.
Conclusione
USF Tampa, Team S1-G4, Nance Spring 2018 Membro di USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 729
