Salta al contenuto principale
HP Envy Sleekbook m6-k010dx LCD Replacement
Cosa ti serve
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 2, immagine 1 di 2 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 4, immagine 1 di 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 5, immagine 1 di 2 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 5, immagine 2 di 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: passo 6, immagine 1 di 2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: passo 6, immagine 2 di 2
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 7, immagine 1 di 1
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 8, immagine 1 di 3 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 8, immagine 2 di 3 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 8, immagine 3 di 3
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 9, immagine 1 di 2 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 9, immagine 2 di 2
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 10, immagine 1 di 2 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 10, immagine 2 di 2
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 11, immagine 1 di 1
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G4, Nance Spring 2018 Membro di USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 939
