Salta al contenuto principale
HP Envy M6-1205DX Palm Rest Replacement
Cosa ti serve
  1. HP Envy M6-1205DX Palm Rest Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Palm Rest Replacement: passo 2, immagine 1 di 1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Palm Rest Replacement: passo 3, immagine 1 di 2 HP Envy M6-1205DX Palm Rest Replacement: passo 3, immagine 2 di 2
    • Remove the battery.
  4. HP Envy M6-1205DX Palm Rest Replacement, Back Panel: passo 4, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
  5. HP Envy M6-1205DX Palm Rest Replacement: passo 5, immagine 1 di 1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Palm Rest Replacement, Palm Rest: passo 6, immagine 1 di 1
    • Set the computer facing upwards again.
    • Using the plastic opening tool gently pry the keyboard up.
  7. HP Envy M6-1205DX Palm Rest Replacement: passo 7, immagine 1 di 3 HP Envy M6-1205DX Palm Rest Replacement: passo 7, immagine 2 di 3 HP Envy M6-1205DX Palm Rest Replacement: passo 7, immagine 3 di 3
    • Flip the white tab on the large ribbon cable upward. Gently pull the large ribbon cable out to remove it.
    • Gently pull the small ribbon cable out to remove it.
  8. HP Envy M6-1205DX Palm Rest Replacement: passo 8, immagine 1 di 3 HP Envy M6-1205DX Palm Rest Replacement: passo 8, immagine 2 di 3 HP Envy M6-1205DX Palm Rest Replacement: passo 8, immagine 3 di 3
    • Gently pull the tension cable to remove it.
  9. HP Envy M6-1205DX Palm Rest Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the four 5.6 mm silver screws.
  10. HP Envy M6-1205DX Palm Rest Replacement: passo 10, immagine 1 di 2 HP Envy M6-1205DX Palm Rest Replacement: passo 10, immagine 2 di 2
    • Use the plastic opening tool to loosen the palm rest from the frame.
    • Once you pry all of the snaps up lift off the palm rest.
Conclusione
Ryan Hatton
Membro da: 11/16/19
634 Reputazione
5 Guide realizzate
IUPUI, Team S2-G2, Wilson Fall 2019 Membro di IUPUI, Team S2-G2, Wilson Fall 2019
IUPUI-WILSON-F19S2G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 293
