Salta al contenuto principale
HP Envy M6-1205DX Fan Replacement
Cosa ti serve
  1. HP Envy M6-1205DX Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Fan Replacement: passo 2, immagine 1 di 1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Fan Replacement: passo 3, immagine 1 di 2 HP Envy M6-1205DX Fan Replacement: passo 3, immagine 2 di 2
    • Remove the battery.
  4. HP Envy M6-1205DX Fan Replacement, Touchpad: passo 4, immagine 1 di 1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Fan Replacement: passo 5, immagine 1 di 1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Fan Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Fan Replacement: passo 7, immagine 1 di 1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Fan Replacement: passo 8, immagine 1 di 2 HP Envy M6-1205DX Fan Replacement: passo 8, immagine 2 di 2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Fan Replacement: passo 9, immagine 1 di 2 HP Envy M6-1205DX Fan Replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Fan Replacement: passo 10, immagine 1 di 2 HP Envy M6-1205DX Fan Replacement: passo 10, immagine 2 di 2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Fan Replacement: passo 11, immagine 1 di 3 HP Envy M6-1205DX Fan Replacement: passo 11, immagine 2 di 3 HP Envy M6-1205DX Fan Replacement: passo 11, immagine 3 di 3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Fan Replacement: passo 12, immagine 1 di 3 HP Envy M6-1205DX Fan Replacement: passo 12, immagine 2 di 3 HP Envy M6-1205DX Fan Replacement: passo 12, immagine 3 di 3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Fan Replacement: passo 13, immagine 1 di 1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Fan Replacement: passo 14, immagine 1 di 2 HP Envy M6-1205DX Fan Replacement: passo 14, immagine 2 di 2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Fan Replacement, Fan: passo 15, immagine 1 di 1
    • Using a Phillips #1, remove the two 10.6 mm screws.
    • Gently pull back on on the cable to unplug it.
  16. HP Envy M6-1205DX Fan Replacement: passo 16, immagine 1 di 1
    • Pull the fan out to remove it.
Conclusione
Altre 7 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 5,719
