Salta al contenuto principale
HP Envy 700-030qe Power Supply Replacement
Cosa ti serve
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: passo 1, immagine 1 di 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: passo 1, immagine 2 di 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: passo 1, immagine 3 di 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: passo 2, immagine 1 di 2 HP Envy 700-030qe Power Supply Replacement: passo 2, immagine 2 di 2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: passo 3, immagine 1 di 1
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: passo 4, immagine 1 di 2 HP Envy 700-030qe Power Supply Replacement: passo 4, immagine 2 di 2
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: passo 5, immagine 1 di 1
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: passo 6, immagine 1 di 1
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: passo 7, immagine 1 di 1
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: passo 8, immagine 1 di 1
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: passo 9, immagine 1 di 1
    • Unplug the power cable going to the fan by pulling straight up.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 5-9, Maness Fall 2015 Membro di Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 45
Tutti i Tempi: 4,250
