Salta al contenuto principale
HP Envy 5660 LCD Replacement
Cosa ti serve
  1. HP Envy 5660 LCD Replacement, LCD: passo 1, immagine 1 di 1
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: passo 2, immagine 1 di 2 HP Envy 5660 LCD Replacement: passo 2, immagine 2 di 2
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: passo 3, immagine 1 di 3 HP Envy 5660 LCD Replacement: passo 3, immagine 2 di 3 HP Envy 5660 LCD Replacement: passo 3, immagine 3 di 3
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: passo 4, immagine 1 di 2 HP Envy 5660 LCD Replacement: passo 4, immagine 2 di 2
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: passo 5, immagine 1 di 2 HP Envy 5660 LCD Replacement: passo 5, immagine 2 di 2
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: passo 6, immagine 1 di 1
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
Conclusione
Ryan Steakley
Membro da: 01/23/18
781 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G6, Livingston Winter 2018 Membro di Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Membri
10 Guide realizzate
2 Commenti
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Replica
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,116
