Salta al contenuto principale
HP Envy 4520 Lid Backing Replacement
  1. HP Envy 4520 Lid Backing Replacement, Lid Backing: passo 1, immagine 1 di 1
    • Grab hold of the front and back of the left side of the lid backing.
    • Face the printer towards you and push the lip of the lid back towards the lid hinges.
    • You may need to apply a lot of pressure to the lid. You will hear two clicks when the hinge releases.
  2. HP Envy 4520 Lid Backing Replacement: passo 2, immagine 1 di 2 HP Envy 4520 Lid Backing Replacement: passo 2, immagine 2 di 2
    • Lay the lid with the white backing facing up with the lip of the lid facing your body.
    • Peel the white backing away gently.
    • There will be a layer of foam glued to the bottom of the white lid backing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 789
