Salta al contenuto principale
HP Envy 4520 Glass Scanner Bed Replacement
Cosa ti serve
  1. HP Envy 4520 Glass Scanner Bed Replacement, Glass Scanner Bed: passo 1, immagine 1 di 2 HP Envy 4520 Glass Scanner Bed Replacement, Glass Scanner Bed: passo 1, immagine 2 di 2
    • Lift the entire scanner bed up.
  2. HP Envy 4520 Glass Scanner Bed Replacement: passo 2, immagine 1 di 2 HP Envy 4520 Glass Scanner Bed Replacement: passo 2, immagine 2 di 2
    • Remove the T10, 13 mm center screw.
  3. HP Envy 4520 Glass Scanner Bed Replacement: passo 3, immagine 1 di 2 HP Envy 4520 Glass Scanner Bed Replacement: passo 3, immagine 2 di 2
    • Remove the large flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
    • Remove the small flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
  4. HP Envy 4520 Glass Scanner Bed Replacement: passo 4, immagine 1 di 2 HP Envy 4520 Glass Scanner Bed Replacement: passo 4, immagine 2 di 2
    • Remove the clip holding the scanner bed up by using the plastic opening tools. Prying the clip away from the the side of the scanner bed.
  5. HP Envy 4520 Glass Scanner Bed Replacement: passo 5, immagine 1 di 2 HP Envy 4520 Glass Scanner Bed Replacement: passo 5, immagine 2 di 2
    • Remove the six 14 mm T10 Hex screws from the main plastic frame.
  6. HP Envy 4520 Glass Scanner Bed Replacement: passo 6, immagine 1 di 3 HP Envy 4520 Glass Scanner Bed Replacement: passo 6, immagine 2 di 3 HP Envy 4520 Glass Scanner Bed Replacement: passo 6, immagine 3 di 3
    • Using the plastic opening tools, pry between the outer shell and the main plastic frame.
  7. HP Envy 4520 Glass Scanner Bed Replacement: passo 7, immagine 1 di 3 HP Envy 4520 Glass Scanner Bed Replacement: passo 7, immagine 2 di 3 HP Envy 4520 Glass Scanner Bed Replacement: passo 7, immagine 3 di 3
    • Remove the black flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling it away from the port.
    • Lift the scanner bed in an upward motion out of the printer.
  8. HP Envy 4520 Glass Scanner Bed Replacement: passo 8, immagine 1 di 2 HP Envy 4520 Glass Scanner Bed Replacement: passo 8, immagine 2 di 2
    • Remove the nine 14 mm T10 Hex screws located around the edge of the scanner bed (Bottom).
    • Pry the two plastic flanges outward to release the glass scanner bed.
  9. HP Envy 4520 Glass Scanner Bed Replacement: passo 9, immagine 1 di 3 HP Envy 4520 Glass Scanner Bed Replacement: passo 9, immagine 2 di 3 HP Envy 4520 Glass Scanner Bed Replacement: passo 9, immagine 3 di 3
    • Remove the glass scanner bed.
    • Then to reassemble align the small gear with the track and gently push down.
Conclusione
Un commento
step 4 - Remove the clip holding the scanner bed up by using the plastic opening tools. Prying the clip away from the the side of the scanner bed.
That clip is designed to be pulled toward the front of the printer to be released from the pin. And push the arm toward the back to snap back in place.
Jack Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,096
