Salta al contenuto principale
HP Envy 4-1030us CPU Fan Replacement
Cosa ti serve
  1. HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: passo 1, immagine 1 di 2 HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us CPU Fan Replacement: passo 2, immagine 1 di 2 HP Envy 4-1030us CPU Fan Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us CPU Fan Replacement, CPU Fan: passo 3, immagine 1 di 1
    • Using the Phillips #0 screwdriver unscrew the two 4.2mm screws fastening the CPU fan to the heatsink and motherboard.
  4. HP Envy 4-1030us CPU Fan Replacement: passo 4, immagine 1 di 2 HP Envy 4-1030us CPU Fan Replacement: passo 4, immagine 2 di 2
    • Carefully lift up the CPU fan to gain better access to the fan cable.
    • Disconnect the fan cable by pulling the cable away from the connector and remove the fan from the device.
Conclusione
USF Tampa, Team S1-G1, Thompson Fall 2017 Membro di USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 376
