Introduzione
This replacement guide will show in-depth step by step tasks to easily remove and replace the battery from the HP Envy 4-1030us. This guide is used in case of a faulty battery, or something caused it to break.
When working with electronic components, we recommend wearing an electrostatic wristband, it is possible for the static electricity present on you to discharge onto one of the components, wearing one of these wristbands and clipping it to a piece of metal will prevent this from happening.
Cosa ti serve
Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
Disconnect the battery cable from the motherboard. This will be found above the battery and below the CPU fan.
To take the cable out, carefully grab the head of the cable and slowly pull it outwards.
Altre 2 persone hanno completato questa guida.
