Salta al contenuto principale
HP Envy 4-1030us Battery Replacement
Cosa ti serve
  1. HP Envy 4-1030us Battery Replacement, Bottom Cover: passo 1, immagine 1 di 2 HP Envy 4-1030us Battery Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Battery Replacement: passo 2, immagine 1 di 2 HP Envy 4-1030us Battery Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Battery Replacement, Battery: passo 3, immagine 1 di 2 HP Envy 4-1030us Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the battery cable from the motherboard. This will be found above the battery and below the CPU fan.
    • To take the cable out, carefully grab the head of the cable and slowly pull it outwards.
  4. HP Envy 4-1030us Battery Replacement: passo 4, immagine 1 di 2 HP Envy 4-1030us Battery Replacement: passo 4, immagine 2 di 2
    • Use the Philips #0 screwdriver to remove the three 4.2mm screws that are securing the battery to the board.
  5. HP Envy 4-1030us Battery Replacement: passo 5, immagine 1 di 2 HP Envy 4-1030us Battery Replacement: passo 5, immagine 2 di 2
    • Then slowly remove the battery from the right side of the battery and then raise it up.
    • Make sure to move the USB Audio board cable away from the battery incase it gets caught.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G1, Thompson Fall 2017 Membro di USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 941
