Salta al contenuto principale
HP Envy 23-d060qd TouchSmart Speaker Replacement
Cosa ti serve
  1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 3, immagine 1 di 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: passo 4, immagine 1 di 1
    • Remove the receiver for the keyboard and mouse with your hands.
  5. HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 5, immagine 1 di 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  6. HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 6, immagine 1 di 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 6, immagine 2 di 2
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  7. HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 7, immagine 1 di 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: passo 7, immagine 2 di 2
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
Conclusione
Zachary Dicks
Membro da: 10/01/15
1.117 Reputazione
7 Guide realizzate
Cal Poly, Team 5-10, Maness Fall 2015 Membro di Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Membri
14 Guide realizzate
Un commento
where to get the replacement speaker???????
Clovis Young - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,390
