Salta al contenuto principale
HP Envy 23-d060qd TouchSmart RAM Replacement
Cosa ti serve
  1. HP Envy 23-d060qd TouchSmart RAM Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 2, immagine 1 di 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 3, immagine 1 di 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: passo 4, immagine 1 di 2 HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Pop off the easy-access cover to get into the RAM module.
  5. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 5, immagine 1 di 2 HP Envy 23-d060qd TouchSmart RAM Replacement: passo 5, immagine 2 di 2
    • Push out the four clips that hold the RAM modules to the side.
    • The RAM modules will pop open after you unclick all four clips.
  6. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 6, immagine 1 di 1
    • Pull out each module.
    • Replace RAM with desired replacement.
    • When substituting your RAM in, make sure to line up the edges with the lines on the RAM compartment so that the RAM is able to fit inside properly.
Conclusione
Altre 4 persone hanno completato questa guida.
Zachary Dicks
Membro da: 10/01/15
1.117 Reputazione
7 Guide realizzate
Cal Poly, Team 5-10, Maness Fall 2015 Membro di Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,205
