Salta al contenuto principale
HP Envy 23-d060qd TouchSmart Fan Replacement
Cosa ti serve
  1. HP Envy 23-d060qd TouchSmart Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 2, immagine 1 di 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 3, immagine 1 di 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: passo 4, immagine 1 di 2 HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate.
  5. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 5, immagine 1 di 2 HP Envy 23-d060qd TouchSmart Fan Replacement: passo 5, immagine 2 di 2
    • Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when you separate wired connections. Pulling on the wires can damage them.
  6. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 6, immagine 1 di 1
    • Remove the three 8mm T15 screws from the fan.
  7. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 7, immagine 1 di 1
    • Pull the fan loose from the computer.
Conclusione
Altre 3 persone hanno completato questa guida.
Zachary Dicks
Membro da: 10/01/15
1.117 Reputazione
7 Guide realizzate
Cal Poly, Team 5-10, Maness Fall 2015 Membro di Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 3,710
