Introduzione
Follow this guide if your HP Envy 17-J013CL Memory module needs to be replaced. Memory, or RAM module, keeps information stored on the computer as long as it is turned on and clears when turned off. Used for quickly access applications. The Memory module is a simple part to replace as it can be done within a few minutes without any hassle. Just remember to keep yourself ground or without static electricity because shocking the module OR the port itself can cause failure.
Cosa ti serve
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
