Salta al contenuto principale
HP Envy 17-J013CL Memory Module Replacement
Cosa ti serve
  1. HP Envy 17-J013CL Memory Module Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Memory Module Replacement: passo 2, immagine 1 di 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Memory Module Replacement: passo 3, immagine 1 di 3 HP Envy 17-J013CL Memory Module Replacement: passo 3, immagine 2 di 3 HP Envy 17-J013CL Memory Module Replacement: passo 3, immagine 3 di 3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Memory Module Replacement, Back Panel: passo 4, immagine 1 di 2 HP Envy 17-J013CL Memory Module Replacement, Back Panel: passo 4, immagine 2 di 2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Memory Module Replacement: passo 5, immagine 1 di 1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Memory Module Replacement, Memory Module: passo 6, immagine 1 di 2 HP Envy 17-J013CL Memory Module Replacement, Memory Module: passo 6, immagine 2 di 2
    • Locate the memory stick inside.
  7. HP Envy 17-J013CL Memory Module Replacement: passo 7, immagine 1 di 2 HP Envy 17-J013CL Memory Module Replacement: passo 7, immagine 2 di 2
    • On both sides of the module, place a thumb on each of the metallic holding pins.
    • Gently pull on the pins to release the spring holding in the module.
  8. HP Envy 17-J013CL Memory Module Replacement: passo 8, immagine 1 di 2 HP Envy 17-J013CL Memory Module Replacement: passo 8, immagine 2 di 2
    • Gently slide the module out of the memory slot.
    • Pay in mind of the module's orientation as it will only go in one way with a little gap in the module to identify orientation.
Conclusione
Matt McBride
Membro da: 02/02/17
845 Reputazione
6 Guide realizzate
USF Tampa, Team 16-6, Blackwell Spring 2017 Membro di USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 677
