Salta al contenuto principale
HP Envy 17-J013CL Battery Replacement
Cosa ti serve
  1. HP Envy 17-J013CL Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Battery Replacement: passo 2, immagine 1 di 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Battery Replacement: passo 3, immagine 1 di 3 HP Envy 17-J013CL Battery Replacement: passo 3, immagine 2 di 3 HP Envy 17-J013CL Battery Replacement: passo 3, immagine 3 di 3
    • Pull the battery out and let go of the battery slider.
Conclusione
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
Altre 2 persone hanno completato questa guida.
Matt McBride
Membro da: 02/02/17
845 Reputazione
6 Guide realizzate
USF Tampa, Team 16-6, Blackwell Spring 2017 Membro di USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Membri
6 Guide realizzate
Un commento
where does one buy a replacement battery for this HP envy17?
brandondelcastillo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,002
