Salta al contenuto principale
HP Envy 17-3070NR Wireless Card Replacement
Cosa ti serve
  1. HP Envy 17-3070NR Wireless Card Replacement, Back Cover: passo 1, immagine 1 di 2 HP Envy 17-3070NR Wireless Card Replacement, Back Cover: passo 1, immagine 2 di 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Wireless Card Replacement: passo 2, immagine 1 di 3 HP Envy 17-3070NR Wireless Card Replacement: passo 2, immagine 2 di 3 HP Envy 17-3070NR Wireless Card Replacement: passo 2, immagine 3 di 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: passo 3, immagine 1 di 3 HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: passo 3, immagine 2 di 3 HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: passo 3, immagine 3 di 3
    • Unscrew 4.5mm Phillips screw.
    • Unplug both antenna connectors by carefully pulling them upwards.
    • During re-assembly make sure to match numbers(1 or 2) on the antenna cable and the wireless card.
  4. HP Envy 17-3070NR Wireless Card Replacement: passo 4, immagine 1 di 3 HP Envy 17-3070NR Wireless Card Replacement: passo 4, immagine 2 di 3 HP Envy 17-3070NR Wireless Card Replacement: passo 4, immagine 3 di 3
    • Pull wireless card up and away from you.
Conclusione
Jasper Lewin
Membro da: 04/21/15
750 Reputazione
6 Guide realizzate
Cal Poly, Team 14-8, Amido Spring 2015 Membro di Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,078
