Salta al contenuto principale
HP Envy 17-3070NR Subwoofer Replacement
Cosa ti serve
  1. HP Envy 17-3070NR Subwoofer Replacement, Back Cover: passo 1, immagine 1 di 2 HP Envy 17-3070NR Subwoofer Replacement, Back Cover: passo 1, immagine 2 di 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Subwoofer Replacement: passo 2, immagine 1 di 3 HP Envy 17-3070NR Subwoofer Replacement: passo 2, immagine 2 di 3 HP Envy 17-3070NR Subwoofer Replacement: passo 2, immagine 3 di 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: passo 3, immagine 1 di 3 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: passo 3, immagine 2 di 3 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: passo 3, immagine 3 di 3
    • Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
    • Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
    • Remove the subwoofer by pulling straight up from the main assembly.
Conclusione
Abby Lentz
Membro da: 04/21/15
586 Reputazione
4 Guide realizzate
Cal Poly, Team 14-8, Amido Spring 2015 Membro di Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 538
