Salta al contenuto principale
HP Envy 17-3070NR Optical Drive Replacement
Cosa ti serve
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: passo 1, immagine 1 di 2 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: passo 1, immagine 2 di 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: passo 2, immagine 1 di 3 HP Envy 17-3070NR Optical Drive Replacement: passo 2, immagine 2 di 3 HP Envy 17-3070NR Optical Drive Replacement: passo 2, immagine 3 di 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: passo 5, immagine 1 di 3 HP Envy 17-3070NR Optical Drive Replacement: passo 5, immagine 2 di 3 HP Envy 17-3070NR Optical Drive Replacement: passo 5, immagine 3 di 3
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Conclusione
Jon Fuson
Membro da: 04/21/15
140 Reputazione
1 Guida realizzata
Cal Poly, Team 14-8, Amido Spring 2015 Membro di Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,206
