Salta al contenuto principale
HP Envy 17-3070NR Battery Replacement
Cosa ti serve
  1. HP Envy 17-3070NR Battery Replacement, Back Cover: passo 1, immagine 1 di 2 HP Envy 17-3070NR Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Battery Replacement: passo 2, immagine 1 di 3 HP Envy 17-3070NR Battery Replacement: passo 2, immagine 2 di 3 HP Envy 17-3070NR Battery Replacement: passo 2, immagine 3 di 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Battery Replacement, Battery: passo 3, immagine 1 di 2 HP Envy 17-3070NR Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
  4. HP Envy 17-3070NR Battery Replacement: passo 4, immagine 1 di 3 HP Envy 17-3070NR Battery Replacement: passo 4, immagine 2 di 3 HP Envy 17-3070NR Battery Replacement: passo 4, immagine 3 di 3
    • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
    • Remove the battery by pulling it straight out away from the computer.
    • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
Conclusione
Altre 5 persone hanno completato questa guida.
Abby Lentz
Membro da: 04/21/15
586 Reputazione
4 Guide realizzate
Cal Poly, Team 14-8, Amido Spring 2015 Membro di Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 8,776
