Introduzione
If your HP Envy 15-u001dx does not turn on or only the peripherals (fan, drives), then you may have a problem with your motherboard. The motherboard is the computer. It connects all the components together, allows them to communicate, and provides power to them.
If you are confident that the problem traces back to the motherboard, then this guide will walk you through the process of removing it.
Before beginning this guide, be sure that the laptop is completely shut down and unplugged. Finally, as you go through the steps in this guide, do so carefully, because electronic components are semi-fragile.
Cosa ti serve
Flip the device over so the bottom is is facing up.
Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
