Salta al contenuto principale
HP Envy 15-u001dx Motherboard Replacement
Cosa ti serve
  1. HP Envy 15-u001dx Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Flip the device over so the bottom is is facing up.
    • Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
  2. HP Envy 15-u001dx Motherboard Replacement: passo 2, immagine 1 di 2 HP Envy 15-u001dx Motherboard Replacement: passo 2, immagine 2 di 2
    • Peel up the small plastic coverings in the middle of the device with the spudger to reveal two more 6.6 mm Phillips #0 screws.
  3. HP Envy 15-u001dx Motherboard Replacement: passo 3, immagine 1 di 2 HP Envy 15-u001dx Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove each of the fourteen 6.6 mm Phillips #0 screws with the Philips #0 screwdriver.
  4. HP Envy 15-u001dx Motherboard Replacement: passo 4, immagine 1 di 1
    • Flip the device over and open it to reveal the keyboard.
    • Use the metal spudger to pry the chassis apart and reveal the inside of the device.
  5. HP Envy 15-u001dx Motherboard Replacement: passo 5, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 5, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 5, immagine 3 di 3
    • Disconnect the T/P cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  6. HP Envy 15-u001dx Motherboard Replacement: passo 6, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 6, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 6, immagine 3 di 3
    • Disconnect the keyboard cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  7. HP Envy 15-u001dx Motherboard Replacement: passo 7, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 7, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 7, immagine 3 di 3
    • Disconnect the battery cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  8. HP Envy 15-u001dx Motherboard Replacement: passo 8, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 8, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 8, immagine 3 di 3
    • Disconnect the AUX/USB cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  9. HP Envy 15-u001dx Motherboard Replacement: passo 9, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 9, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 9, immagine 3 di 3
    • Disconnect the cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  10. HP Envy 15-u001dx Motherboard Replacement: passo 10, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 10, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 10, immagine 3 di 3
  11. HP Envy 15-u001dx Motherboard Replacement: passo 11, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 11, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 11, immagine 3 di 3
  12. HP Envy 15-u001dx Motherboard Replacement: passo 12, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 12, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 12, immagine 3 di 3
    • Disconnect the cable by gently pulling it out. The spudger may be used to help loosen it.
  13. HP Envy 15-u001dx Motherboard Replacement: passo 13, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 13, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 13, immagine 3 di 3
    • Remove the three 4.0 mm Phillips #0 screws with the Phillips #0 screwdriver on the fan.
    • Remove the fan by pulling it out of the chassis.
    • The connector tends to get stuck and forceful pulling will break it. Use the spudger to loosen the connector on each side.
  14. HP Envy 15-u001dx Motherboard Replacement: passo 14, immagine 1 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 14, immagine 2 di 3 HP Envy 15-u001dx Motherboard Replacement: passo 14, immagine 3 di 3
    • This connector may be hard to see because it is connected on the underside of the motherboard.
  15. HP Envy 15-u001dx Motherboard Replacement: passo 15, immagine 1 di 1
    • Remove each of the six 4.0 mm screws with the Philips #0 screwdriver.
  16. HP Envy 15-u001dx Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove each of the three 4.0 mm screws around the fan with the Philips #0 screwdriver.
    • The fan will now be loose, and easy to lift out.
  17. HP Envy 15-u001dx Motherboard Replacement: passo 17, immagine 1 di 2 HP Envy 15-u001dx Motherboard Replacement: passo 17, immagine 2 di 2
    • Gently pry the heat sink loose to release the motherboard.
  18. HP Envy 15-u001dx Motherboard Replacement: passo 18, immagine 1 di 2 HP Envy 15-u001dx Motherboard Replacement: passo 18, immagine 2 di 2
    • Disconnect the wifi card from the motherboard and remove the motherboard from the rest of the device.
  19. HP Envy 15-u001dx Motherboard Replacement: passo 19, immagine 1 di 1
    • The disconnected motherboard should look like the indicated photo.
Conclusione
IUPUI, Team S1-G1, Henning Fall 2019 Membro di IUPUI, Team S1-G1, Henning Fall 2019
IUPUI-HENNING-F19S1G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 510
