Salta al contenuto principale
HP Envy 15-u001dx Cooling Fan Replacement
Cosa ti serve
  1. HP Envy 15-u001dx Cooling Fan Replacement, HP Envy 15-u001dx Disassembly: passo 1, immagine 1 di 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Cooling Fan Replacement: passo 5, immagine 1 di 2 HP Envy 15-u001dx Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: passo 6, immagine 1 di 2 HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: passo 6, immagine 2 di 2
    • Remove the three 4.5 mm Phillips #0 screws holding the fan in place.
  7. HP Envy 15-u001dx Cooling Fan Replacement: passo 7, immagine 1 di 1
    • Gently detach the connector with a spudger and the fan is free to be removed.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 9-4, Lacy Fall 2016 Membro di USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,312
