Salta al contenuto principale
HP Envy 15-u001dx Chassis Replacement
Cosa ti serve
  1. HP Envy 15-u001dx Chassis Replacement, Motherboard: passo 1, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement, Motherboard: passo 1, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement, Motherboard: passo 1, immagine 3 di 3
    • Flip the device over so the bottom is is facing up.
    • Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
  2. HP Envy 15-u001dx Chassis Replacement: passo 2, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 2, immagine 2 di 2
    • Peel up the small plastic coverings in the middle of the device with the spudger to reveal two more 6.6 mm Phillips #0 screws.
  3. HP Envy 15-u001dx Chassis Replacement: passo 3, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 3, immagine 2 di 2
    • Remove each of the fourteen 6.6 mm Phillips #0 screws with the Philips #0 screwdriver.
  4. HP Envy 15-u001dx Chassis Replacement: passo 4, immagine 1 di 1
    • Flip the device over and open it to reveal the keyboard.
    • Use the metal spudger to pry the chassis apart and reveal the inside of the device.
  5. HP Envy 15-u001dx Chassis Replacement: passo 5, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 5, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 5, immagine 3 di 3
    • Disconnect the T/P cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  6. HP Envy 15-u001dx Chassis Replacement: passo 6, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 6, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 6, immagine 3 di 3
    • Disconnect the keyboard cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  7. HP Envy 15-u001dx Chassis Replacement: passo 7, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 7, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 7, immagine 3 di 3
    • Disconnect the battery cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  8. HP Envy 15-u001dx Chassis Replacement: passo 8, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 8, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 8, immagine 3 di 3
    • Disconnect the AUX/USB cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  9. HP Envy 15-u001dx Chassis Replacement: passo 9, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 9, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 9, immagine 3 di 3
    • Disconnect the cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  10. HP Envy 15-u001dx Chassis Replacement: passo 10, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 10, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 10, immagine 3 di 3
  11. HP Envy 15-u001dx Chassis Replacement: passo 11, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 11, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 11, immagine 3 di 3
  12. HP Envy 15-u001dx Chassis Replacement: passo 12, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 12, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 12, immagine 3 di 3
    • Disconnect the cable by gently pulling it out. The spudger may be used to help loosen it.
  13. HP Envy 15-u001dx Chassis Replacement: passo 13, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 13, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 13, immagine 3 di 3
    • Remove the three 4.0 mm Phillips #0 screws with the Phillips #0 screwdriver on the fan.
    • Remove the fan by pulling it out of the chassis.
    • The connector tends to get stuck and forceful pulling will break it. Use the spudger to loosen the connector on each side.
  14. HP Envy 15-u001dx Chassis Replacement: passo 14, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 14, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 14, immagine 3 di 3
    • This connector may be hard to see because it is connected on the underside of the motherboard.
  15. HP Envy 15-u001dx Chassis Replacement: passo 15, immagine 1 di 1
    • Remove each of the six 4.0 mm screws with the Philips #0 screwdriver.
  16. HP Envy 15-u001dx Chassis Replacement: passo 16, immagine 1 di 1
    • Remove each of the three 4.0 mm screws around the fan with the Philips #0 screwdriver.
    • The fan will now be loose, and easy to lift out.
  17. HP Envy 15-u001dx Chassis Replacement: passo 17, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 17, immagine 2 di 2
    • Gently pry the heat sink loose to release the motherboard.
  18. HP Envy 15-u001dx Chassis Replacement: passo 18, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 18, immagine 2 di 2
    • Disconnect the wifi card from the motherboard and remove the motherboard from the rest of the device.
  19. HP Envy 15-u001dx Chassis Replacement: passo 19, immagine 1 di 1
    • The disconnected motherboard should look like the indicated photo.
  20. HP Envy 15-u001dx Chassis Replacement, Chassis: passo 20, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement, Chassis: passo 20, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement, Chassis: passo 20, immagine 3 di 3
    • Remove the three 4mm Phillips #0 screws that attach the battery to the chassis.
    • Once all three 4mm Phillips #0 screws are out, lift the battery out of the chassis.
  21. HP Envy 15-u001dx Chassis Replacement: passo 21, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 21, immagine 2 di 2
    • Carefully, use the spudger, to loosen the I/O port board connector.
    • Once the connector is loose, simply pull it away.
  22. HP Envy 15-u001dx Chassis Replacement: passo 22, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 22, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 22, immagine 3 di 3
    • Remove the 4mm Phillips #0 screw that attaches the left speaker to the chassis.
    • Lift the left side speaker out of the chassis.
    • Remove the 4mm Phillips #0 screw that attaches the right speaker to the chassis.
  23. HP Envy 15-u001dx Chassis Replacement: passo 23, immagine 1 di 3 HP Envy 15-u001dx Chassis Replacement: passo 23, immagine 2 di 3 HP Envy 15-u001dx Chassis Replacement: passo 23, immagine 3 di 3
    • Remove the 4mm Phillips #0 screw attaching the volume circuitry board to the chassis.
    • Once screw has been removed, then simply pull the circuitry board out.
  24. HP Envy 15-u001dx Chassis Replacement: passo 24, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 24, immagine 2 di 2
    • Remove the 4 mm Phillips #0 screws attaching the power button circuitry board to the chassis.
    • Once all the screws are removed, then simply pull the circuitry board out.
  25. HP Envy 15-u001dx Chassis Replacement: passo 25, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 25, immagine 2 di 2
    • Remove the two 4mm Phillips #0 screws that attach the storage device to the chassis.
    • Then pull up on the storage device to get it pop it out of the chassis.
  26. HP Envy 15-u001dx Chassis Replacement: passo 26, immagine 1 di 1
    • Remove the 6.6mm Phillips #0 screws that attach the screen to the right side of the chassis.
  27. HP Envy 15-u001dx Chassis Replacement: passo 27, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 27, immagine 2 di 2
    • Remove the two 6.6mm Phillips #0 screws that attach the hinge to the chassis on the left side.
  28. HP Envy 15-u001dx Chassis Replacement: passo 28, immagine 1 di 2 HP Envy 15-u001dx Chassis Replacement: passo 28, immagine 2 di 2
    • After you remove the screen, all that is left is the chassis!
Conclusione
Samuel Olubakinde
Membro da: 11/04/19
169 Reputazione
1 Guida realizzata
IUPUI, Team S1-G1, Henning Fall 2019 Membro di IUPUI, Team S1-G1, Henning Fall 2019
IUPUI-HENNING-F19S1G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,058
