Salta al contenuto principale
HP Elitebook x360 1040 G5 Touchpad Replacement
Cosa ti serve
  1. HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: passo 1, immagine 1 di 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: passo 1, immagine 2 di 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Touchpad Replacement: passo 2, immagine 1 di 2 HP Elitebook x360 1040 G5 Touchpad Replacement: passo 2, immagine 2 di 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: passo 3, immagine 1 di 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: passo 3, immagine 2 di 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Touchpad Replacement: passo 4, immagine 1 di 3 HP Elitebook x360 1040 G5 Touchpad Replacement: passo 4, immagine 2 di 3 HP Elitebook x360 1040 G5 Touchpad Replacement: passo 4, immagine 3 di 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: passo 5, immagine 1 di 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: passo 5, immagine 2 di 2
    • Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the touchpad assembly.
  6. HP Elitebook x360 1040 G5 Touchpad Replacement: passo 6, immagine 1 di 3 HP Elitebook x360 1040 G5 Touchpad Replacement: passo 6, immagine 2 di 3 HP Elitebook x360 1040 G5 Touchpad Replacement: passo 6, immagine 3 di 3
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the left hand side.
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the right hand side.
  7. HP Elitebook x360 1040 G5 Touchpad Replacement: passo 7, immagine 1 di 1
    • Gently pull up on the top two corners of the touchpad and remove it from the laptop.
Conclusione
Corey Agena
Membro da: 04/21/19
833 Reputazione
6 Guide realizzate
Cal Poly, Team S1-G4, Maness Spring 2019 Membro di Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 22
Tutti i Tempi: 797
