Salta al contenuto principale
HP Elitebook x360 1040 G5 Screen display Replacement
Cosa ti serve
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: passo 1, immagine 1 di 3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: passo 1, immagine 2 di 3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: passo 1, immagine 3 di 3
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: passo 2, immagine 1 di 3 HP Elitebook x360 1040 G5 Screen display Replacement: passo 2, immagine 2 di 3 HP Elitebook x360 1040 G5 Screen display Replacement: passo 2, immagine 3 di 3
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: passo 3, immagine 1 di 2 HP Elitebook x360 1040 G5 Screen display Replacement: passo 3, immagine 2 di 2
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: passo 4, immagine 1 di 3 HP Elitebook x360 1040 G5 Screen display Replacement: passo 4, immagine 2 di 3 HP Elitebook x360 1040 G5 Screen display Replacement: passo 4, immagine 3 di 3
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: passo 5, immagine 1 di 3 HP Elitebook x360 1040 G5 Screen display Replacement: passo 5, immagine 2 di 3 HP Elitebook x360 1040 G5 Screen display Replacement: passo 5, immagine 3 di 3
    • Remove the screen from the laptop.
Conclusione
Tyler A Cobb
Membro da: 09/03/19
321 Reputazione
2 Guide realizzate
IUPUI, Team S1-G1, Hovde Fall 2019 Membro di IUPUI, Team S1-G1, Hovde Fall 2019
IUPUI-HOVDE-F19S1G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,838
