Salta al contenuto principale
HP Elitebook 8570w Optical Drive Replacement
Cosa ti serve
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: passo 2, immagine 1 di 1
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: passo 3, immagine 1 di 1
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: passo 4, immagine 1 di 2 HP Elitebook 8570w Optical Drive Replacement: passo 4, immagine 2 di 2
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
Conclusione
MJ Routh
Membro da: 11/06/17
465 Reputazione
3 Guide realizzate
Baylor, Team S8-G5, Johnson Fall 2017 Membro di Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,746
