Salta al contenuto principale
HP Elitebook 8570w Keyboard Replacement
Cosa ti serve
  1. HP Elitebook 8570w Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Begin by removing the back cover of the computer.
    • Push the marked slider to the right.
    • While pushing the slider, pull the cover towards yourself to remove.
  2. HP Elitebook 8570w Keyboard Replacement: passo 2, immagine 1 di 1
    • Locate the 3 screws marked in the photo.
    • Using a Phillips screwdriver, unscrew all 3 0.8mm screws completely and place to the side.
  3. HP Elitebook 8570w Keyboard Replacement: passo 3, immagine 1 di 2 HP Elitebook 8570w Keyboard Replacement: passo 3, immagine 2 di 2
    • Flip the computer so it is laying on its side.
    • Using your fingers or a tool, begin to wedge back/pull off the top of the keyboard panel.
    • Once freeing the keyboard panel from the computer, it should look like photo #2.
  4. HP Elitebook 8570w Keyboard Replacement: passo 4, immagine 1 di 1
    • Locate all 3 places of attachment marked in the photo.
    • Each de-attachment is explained in the following steps.
  5. HP Elitebook 8570w Keyboard Replacement: passo 5, immagine 1 di 2 HP Elitebook 8570w Keyboard Replacement: passo 5, immagine 2 di 2
    • Locate the white rectangle base beneath the blue and white strip attached to the computer and keyboard.
    • Using a wedging tool, pull the white base up slightly to loosen the grip on the blue and white strip.
    • With the white base slightly risen, use tweezers to carefully pull out/remove the strip from the computer.
  6. HP Elitebook 8570w Keyboard Replacement: passo 6, immagine 1 di 2 HP Elitebook 8570w Keyboard Replacement: passo 6, immagine 2 di 2
    • Locate the white rectangle base beneath the burn orange strip attached to the computer and the keyboard.
    • Like the previous step, use a plastic or nylon tool to slightly raise the white base to loosen the grip on the ribbon cable.
    • Using tweezers or your fingers, carefully pull up on the ribbon cable to completely detach it from the computer.
  7. HP Elitebook 8570w Keyboard Replacement: passo 7, immagine 1 di 1
    • Locate the black rectangle base at the bottom of the thick ribbon cable.
    • Like previous steps, use a tool to wedge the base upward to slightly lift it in order to loosen the grip on the silver ribbon cable.
    • While the base is lifted, use your fingers to carefully pull out the silver ribbon cable thus freeing it from the computer.
Conclusione
Altre 3 persone hanno completato questa guida.
Marko Tardio
Membro da: 11/06/17
226 Reputazione
1 Guida realizzata
Baylor, Team S8-G5, Johnson Fall 2017 Membro di Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 7,259
