Introduzione
This replacement guide will show you how to disconnect the display from your HP EliteBook 8570w. It consists of 7 moderately difficult steps that should guide you successfully.
Cosa ti serve
With the computer opened, locate the square buttons on both bottom corners of the display.
Using a tool or finger, wedge the squares off revealing a screw on each corner.
Use a Phillips #00 screwdriver to unscrew all four 0.8 mm screws from the left side of the display frame. Repeat for the right side.
Push the metal plates/rods that were attached to the display towards the top cover.
The display should be completely free of the top cover and able to lay flat on the keyboard (refer to photo #2).
With the display laying on the keyboard, locate the black square panel marked in the photo.
Grab the side marked in photo #2 and pull it towards you peeling off the surrounding tape and releasing it from the actual display board.
This will then remove the connection between the display and the top cover.
Altre 4 persone hanno completato questa guida.
2 Commenti
this guide is really bad, dangerous and should be removed !
at step 3 you crack and kill the existing display. If it was still somewhat working before now you are assured it is completely dead !
agreed, step 3 should use the opening tool on a top corner of the bezel, not against the screen. you just screwed up the screen if it worked at all
