Salta al contenuto principale
HP Elitebook 8460p RAM (Random Access Memory) Replacement
Cosa ti serve
  1. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Battery: passo 1, immagine 1 di 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    what if it does not work,what does that mean?
    julia melrose - Replica
  2. HP Elitebook 8460p RAM (Random Access Memory) Replacement: passo 2, immagine 1 di 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Back Panel: passo 3, immagine 1 di 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p RAM (Random Access Memory) Replacement: passo 4, immagine 1 di 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): passo 5, immagine 1 di 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): passo 5, immagine 2 di 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): passo 5, immagine 3 di 3
    • Attach ESD strap around your wrist and to a ground.
    • Using both thumbs, locate the two metal clips and pull them apart, allowing the RAM chip to pop upwards.
  6. HP Elitebook 8460p RAM (Random Access Memory) Replacement: passo 6, immagine 1 di 2 HP Elitebook 8460p RAM (Random Access Memory) Replacement: passo 6, immagine 2 di 2
    • Pull the RAM chip straight out and repeat for the second chip.
    • If installing new RAM chip(s), seat the chip firmly in the RAM slot and push down until the metal clips snap in place.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Great job thanks
Charles Tighe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,902
