Salta al contenuto principale
HP Elitebook 8460p Optical Drive Replacement
Cosa ti serve
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: passo 2, immagine 1 di 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: passo 3, immagine 1 di 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: passo 4, immagine 1 di 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, immagine 1 di 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, immagine 2 di 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, immagine 3 di 3
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: passo 6, immagine 1 di 2 HP Elitebook 8460p Optical Drive Replacement: passo 6, immagine 2 di 2
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: passo 7, immagine 1 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 7, immagine 2 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 7, immagine 3 di 3
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: passo 8, immagine 1 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 8, immagine 2 di 3 HP Elitebook 8460p Optical Drive Replacement: passo 8, immagine 3 di 3
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,019
