Salta al contenuto principale
HP Elitebook 8460p Modem Card Replacement
Cosa ti serve
  1. HP Elitebook 8460p Modem Card Replacement, Battery: passo 1, immagine 1 di 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: passo 2, immagine 1 di 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: passo 3, immagine 1 di 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: passo 4, immagine 1 di 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: passo 5, immagine 1 di 2 HP Elitebook 8460p Modem Card Replacement, Modem Card: passo 5, immagine 2 di 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: passo 6, immagine 1 di 2 HP Elitebook 8460p Modem Card Replacement: passo 6, immagine 2 di 2
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: passo 7, immagine 1 di 2 HP Elitebook 8460p Modem Card Replacement: passo 7, immagine 2 di 2
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,577
