Salta al contenuto principale
HP Elitebook 8460p Bluetooth Card Replacement
  1. HP Elitebook 8460p Bluetooth Card Replacement, Battery: passo 1, immagine 1 di 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Bluetooth Card Replacement: passo 2, immagine 1 di 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Bluetooth Card Replacement, Back Panel: passo 3, immagine 1 di 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Bluetooth Card Replacement: passo 4, immagine 1 di 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: passo 5, immagine 1 di 2 HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: passo 5, immagine 2 di 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a fingernail, grasp the small connector and separate the connector from the Bluetooth card.
  6. HP Elitebook 8460p Bluetooth Card Replacement: passo 6, immagine 1 di 1
    • Grasp the Bluetooth card and pull it straight out to the left.
Conclusione
Altre 7 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 75
Tutti i Tempi: 5,608
