Introduzione
If your PC is overheating, you may simply have to dust and get rid of lint off the devices fan and heatsink or replacing the fan and heatsink on your HP EliteBook 840 G1
Cosa ti serve
Slide the latch, to the right, away from the lock symbol.
Slide the cover away from the latch to remove it.
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Identify the RAM and the pull tabs that will be used in the next step.
In order to take out the fan and heatsink the plastic cover must first be taken off.
Remove the eight 2 mm Phillips #1 screws.
Use the plastic opening tools to remove the keyboard, starting at one of the top corners. You need to lift the top side and then takeing it out moving the keyboard towards the screen.
Once the keyboard is removed, detach the ribbons connecting the keyboard to the laptop by prying the small tab and sliding the ribbon out.
Altre 16 persone hanno completato questa guida.
4 Commenti
Quality guide. Very logical. Thank you.
perfectly done, thank you!
Do you need to remove the keyboard for replacing the tehmal paste?
You don’t need to remove the keyoard to replace the thermal paste :)
Brendan -
