Salta al contenuto principale
HP Elitebook 820 G1 RAM Replacement
Cosa ti serve
  1. HP Elitebook 820 G1 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 RAM Replacement: passo 2, immagine 1 di 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 RAM Replacement: passo 3, immagine 1 di 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 RAM Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • The latches are spring assisted and the RAM module will lift for removal.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S5-G1, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,135
