Salta al contenuto principale
Introduzione
Hard drives are mechanical and begin to fail with age. Drops and physical damage can cause the drive to fail sooner. Follow this guide to the replace the hard drive. When replacing the hard drive, the Torx screws will be transferred to the new drive.
Parti
Nessuna parte specificata.
  1. Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. Remove the back cover and you will then be able to see the battery.
    • Remove the back cover and you will then be able to see the battery.
  3. Unlatch the two latches securing the battery in the case.
    • Unlatch the two latches securing the battery in the case.
  4. Use a plastic opening tool to lift and remove the battery.
    • Use a plastic opening tool to lift and remove the battery.
  5. Remove the four 8mm screws with the T7 philip's head.
    • Remove the four 8mm screws with the T7 philip's head.
  6. Remove the hard drive casing.
    • Remove the hard drive casing.
    • Unscrew the four 8mm torx screws, holding the hard drive.
  7. Remove the hard drive from the casing and replace it.
    • Remove the hard drive from the casing and replace it.
Conclusione
USF Tampa, Team S5-G1, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 70
Tutti i Tempi: 1,348
