Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Batteries become consumed over time and hold less of a charge. After running diagnostics, follow this replacement guide.
Parti
Nessuna parte specificata.
  1. Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. Remove the back cover and you will then be able to see the battery.
    • Remove the back cover and you will then be able to see the battery.
  3. Unlatch the two latches securing the battery in the case.
    • Unlatch the two latches securing the battery in the case.
  4. Use a plastic opening tool to lift and remove the battery.
    • Use a plastic opening tool to lift and remove the battery.
Conclusione
USF Tampa, Team S5-G1, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 142
Tutti i Tempi: 7,500
