Introduzione
There are 2 RAM slots in the 6930p Laptop. One is the expansion slot and accessible from the underside of the device, the other is the default location for factory installed RAM and is located under the keyboard. This guide focuses on the expansion slot
Parti
Nessuna parte richiesta.
Flip laptop over and locate the battery release button
  • Flip laptop over and locate the battery release button
  • Push release button to the left to release battery and gently pull battery from the laptop
Aggiungi Commento
Locate the RAM expansion slot cover on the bottom of the laptop
  • Locate the RAM expansion slot cover on the bottom of the laptop
  • Loosen the PM2.0×5.0 captive screw and remove the cover.
Aggiungi Commento
  • Install RAM module into the RAM slot on an angle of around 30 degrees
  • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
  • Check to ensure the metal tabs are holding the RAM module down on both sides
  • Reinstall the RAM cover
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Richdave
Membro da: 09/04/2010
28.204 Reputazione
30 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
747 Guide realizzate
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Replica
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 36
Tutti i Tempi: 11,339
