Salta al contenuto principale
HP Elitebook 2740p WI-FI card Replacement
Cosa ti serve
  1. HP Elitebook 2740p WI-FI  card Replacement, WI-FI  Card: passo 1, immagine 1 di 2 HP Elitebook 2740p WI-FI  card Replacement, WI-FI  Card: passo 1, immagine 2 di 2
    • Place the laptop face down in front of you.
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
    • Remove the back panel.
  2. HP Elitebook 2740p WI-FI  card Replacement: passo 2, immagine 1 di 1
    • Remove the two wires that are attached to the WiFi card.
  3. HP Elitebook 2740p WI-FI  card Replacement: passo 3, immagine 1 di 3 HP Elitebook 2740p WI-FI  card Replacement: passo 3, immagine 2 di 3 HP Elitebook 2740p WI-FI  card Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the two 3 mm Philips head screws from the WiFi card.
    • Remove the card.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 26
Tutti i Tempi: 604
