Salta al contenuto principale
HP Elitebook 2740p Screen Replacement
Cosa ti serve
  1. HP Elitebook 2740p Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the lock tab to the right.
  2. HP Elitebook 2740p Screen Replacement: passo 2, immagine 1 di 1
    • Lift and remove the battery from the battery compartment.
  3. HP Elitebook 2740p Screen Replacement, Screen: passo 3, immagine 1 di 3 HP Elitebook 2740p Screen Replacement, Screen: passo 3, immagine 2 di 3 HP Elitebook 2740p Screen Replacement, Screen: passo 3, immagine 3 di 3
    • Locate the radio antenna on the right side of the top edge of the screen. Slide the latch to release the antenna.
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws recessed in the antenna housing.
  4. HP Elitebook 2740p Screen Replacement: passo 4, immagine 1 di 3 HP Elitebook 2740p Screen Replacement: passo 4, immagine 2 di 3 HP Elitebook 2740p Screen Replacement: passo 4, immagine 3 di 3
    • Use a metal spudger to separate bezel from laptop body. there are tabs holding the bezel on along the entire bezel.
    • Pay special attention to the hinge cover at the bottom. It has tabs at both the top and bottom.
    • Remove the bezel from the laptop.
  5. HP Elitebook 2740p Screen Replacement: passo 5, immagine 1 di 3 HP Elitebook 2740p Screen Replacement: passo 5, immagine 2 di 3 HP Elitebook 2740p Screen Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the eight 4 mm screws that hold the frame of the screen in place.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw at the corner of the frame.
  6. HP Elitebook 2740p Screen Replacement: passo 6, immagine 1 di 3 HP Elitebook 2740p Screen Replacement: passo 6, immagine 2 di 3 HP Elitebook 2740p Screen Replacement: passo 6, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws that hold the tilt button in place.
    • Remove the tilt button.
  7. HP Elitebook 2740p Screen Replacement: passo 7, immagine 1 di 3 HP Elitebook 2740p Screen Replacement: passo 7, immagine 2 di 3 HP Elitebook 2740p Screen Replacement: passo 7, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the three screws that secure the tablet-mode button board.
    • Disconnect the two blue ribbon cables and gently pull them free.
    • Remove the PCB board from the screen housing.
  8. HP Elitebook 2740p Screen Replacement: passo 8, immagine 1 di 3 HP Elitebook 2740p Screen Replacement: passo 8, immagine 2 di 3 HP Elitebook 2740p Screen Replacement: passo 8, immagine 3 di 3
    • Remove the gray rubber pad at the top of the screen next to the camera.
    • Remove the 3mm screw with a Phillips #0 screwdriver
    • Carefully tilt the screen down onto the keayboard
  9. HP Elitebook 2740p Screen Replacement: passo 9, immagine 1 di 2 HP Elitebook 2740p Screen Replacement: passo 9, immagine 2 di 2
    • Fold the protective foil back from the ribbon cables.
  10. HP Elitebook 2740p Screen Replacement: passo 10, immagine 1 di 3 HP Elitebook 2740p Screen Replacement: passo 10, immagine 2 di 3 HP Elitebook 2740p Screen Replacement: passo 10, immagine 3 di 3
    • Unseat display ribbon cables.
    • Ribbon cables are secured with tape. Do not force the cables out of their sockets.
    • Remove the screen.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,489
