Introduzione
If your HP Elitebook 2740p's screen is cracked, the toch function does not work, or has an excessive amount of dead pixels, you may need to replace it. With this guide, you will learn how to do so step-by-step.
Cosa ti serve
Locate the radio antenna on the right side of the top edge of the screen. Slide the latch to release the antenna.
Use a Phillips #0 screwdriver to remove the two 4 mm screws recessed in the antenna housing.
Altre 4 persone hanno completato questa guida.
