Salta al contenuto principale
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
Cosa ti serve
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: passo 1, immagine 1 di 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: passo 1, immagine 2 di 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: passo 1, immagine 3 di 3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 2, immagine 1 di 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 2, immagine 2 di 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 2, immagine 3 di 3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 3, immagine 1 di 2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 3, immagine 2 di 2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 1-24, Maness Fall 2015 Membro di Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Membri
14 Guide realizzate
2 Commenti
where can i buy a replace cage for the hard drive?
Thomas Dickson - Replica
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 85
Tutti i Tempi: 8,421
