Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide is meant to show you how to replace a broken, malfunctioning, corrupted or otherwise inadequate drive. This guide requires a small amount of technical knowledge and is considered a moderately easy guide. There are no hazards associated with this guide, but it is vital to keep track of all the small parts that are removed during the process.
Parti
Nessuna parte specificata.
  1. Place the computer screen down on a flat surface. Push the two locking latches  to the unlocked position. Push the cover toward the top of the computer and lift up.
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. Grasp the handle on the hard drive cage to the left of the stand. It is marked with green. Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer. Pull the entire cage up and out of the device.
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side. Once all the screws are removed, lift the drive out of the cage.
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 1-24, Maness Fall 2015 Membro di Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Membri
14 Guide realizzate
where can i buy a replace cage for the hard drive?
Thomas Dickson - Replica
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 98
Tutti i Tempi: 5,074
